08-14-2020
03:43
13:46
08-14-2020
03:43
13:46
Thank you. I had to do a factory reset so wanted to know that I have the right firmware. However, since I did the reset my Versa 2 is no longer functioning. It just has the Fitbit logo and cycles through all the languages. Its been doing this for about 2 hours now.
08-14-2020 13:48
08-14-2020 13:48
Hi there @Holly33, welcome to the Community Forums. Thanks for the details provided in your post, I'll be glad to help you to set up your Versa 2 to your Fitbit app again.
Please note that the difficulty you are having to set up your Versa 2 usually happens when you perform a factory reset without first unpairing the watch. In order to solve this issue, I'd recommend trying the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
If you want to know the current firmware version installed on your watch, in the Fitbit app tap the Today tab > your profile picture > your device image (the firmware version number appears under your device's name) or on your Versa 2, in the Settings app > About or Device Info.
Let me know if you need further assistance, I'll be around.
Best Answer08-14-2020 13:48
08-14-2020 13:48
Best Answer08-19-2020 07:52
08-19-2020 07:52
I am having this issue as well. After doing a suggested factory reset, it won't reconnect to my app. I've unpaired my device from my account, uninstalled the FitBit app, turned my Bluetooth on and off, restarted my device, reinstalled FitBit app, restarted my Versa 2-- nothing is making it work. The app finds the device, then once I put in the code it never connects. Is there anything else I can do or is my Versa 2 just dead and needs to be replaced? It is only 9 months old and up until doing this reset (after beta testing), I've never had any issues!
Best Answer08-20-2020 08:26 - edited 06-23-2024 06:53
Hi there @jfk0621, welcome on board. Thanks for sharing your recent experience with your Versa 2 and for following the recommendations I posted above.
I've seen that you contacted our Support Team after posting here to report about this issue and they tried helping you to get your watch fixed. I'm glad to hear about your replacement!
Let me know if there's anything else I may do to help you in the meantime.
Best Answer09-09-2020 13:41
09-09-2020 13:41
How do I get my Versa 2 to reset up when it won't turn on. The fitbit logo just flashes and so it won't sych with my Bluetooth on my apple or the app again. Before I tried these steps it said last syched last night and couldn't find it.
Best Answer09-10-2020 06:26 - edited 11-14-2023 04:02
Hi there @jamoore151, thanks for stopping by in the Community Forums. I appreciate the details provided in your post about the inconveniences you've been having with your Versa 2 and your efforts in following the tips and recommendations I provided above.
While reading your post I was wondering if your Versa 2 vibrates when you connect it to the charger? If it doesn't, please try the steps below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Let me know if you need further assistance.
Best Answer09-10-2020 09:41
09-10-2020 09:41
Sorry but this is zero help. My Fitbit Logo has just been flashing since yesterday morning. It was dead this morning I charged it...although it doesn't show it charging it did charge. But still nothing just the slow heart beat of the Fitbit Logo. I went through the process of deleting the app and device as stated in other chats to try to fix this and now I can not add my fitbit back, my devices....both phones won't find it now...indicated it is off....it's not off just not responding. Just the Logo every few seconds.
Best Answer09-11-2020 07:14
09-11-2020 07:14
Finally gave up on selfhelp and called yesterday. The customer service rep I spoke to was great. My watch will not go back to factory setting or anything else. Just keeps slowing about every 10 seconds flashing the FitBit logo. Fortunatly for me I am still under warranty so a new fitbit is now on it's way.
Best Answer12-25-2021 18:13
12-25-2021 18:13
Did you ever get this fixed? I have been trying for almost 4 months to get my Versa 2 to connect with my fitbit app and it just wont. It freezes every **ahem** time after I enter the 4 digit code. Idk what to do?! I have bought and returned both the Versa 3 and Sense bc they are inferior to the Versa 2. Neither correctly track my steps. Im just so disappointed in fitbit.
