08-29-2022
10:16
16:57
08-29-2022
10:16
16:57
My Fitbit keeps coming up with pair and as many times as I’ve tried it will not pair, even when I’ve reinstalled still won’t pair. Any ideas on what more I can try?
08-29-2022 16:59 - edited 06-22-2024 06:50
Hi there, @Caz279. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
In addition to the steps you've done so far, please try the following:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope this helps.
Hope this helps.
08-30-2022 02:03
08-30-2022 02:03
08-30-2022 02:42
08-30-2022 02:42
I had similar problems with my Versa 2. At first the microphone stopped working for text messages etc., then I stopped receiving all notifications on my Versa, then the date and time fell completely out of sync.
Going through normal troubleshooting of long-pressing the button to power cycle the Versa, turn Bluetooth on the phone off then on again, re-pair etc. all failed. The Versa 2 would get as far as giving me the 4 digit pairing code and then the Fitbit app would always fail to pair.
The only thing that fixed it was factory resetting the Versa. Open Settings, go all the way to the bottom and tap About, then go all the way to the bottom again to tap Factory Reset.
08-30-2022 08:19 - edited 08-14-2023 09:53
@Caz279 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. We hope your issue is solved soon.
Hi, @mobiusevalon. Welcome on board. Thanks for sharing the steps that worked for you. I'm glad to hear you're back on track!
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
