09-22-2024
04:02
04:40
09-22-2024
04:02
04:40
Hello, would like to seek advice/fixes for the current issue I'm facing.
My Versa 2 was working fine, it was low on battery so I went to get it charged. Ever since then it has not been able to connect to the app.
I've tried doing a factory reset to the watch but I keep getting stuck on the white Fitbit logo (after keying in the 4 digit pin).
It seems like my phone can recognise and link up with the Versa 2, just that it cannot pair up.
Anyone faced the same issue and found a fix? Thanks!
09-22-2024 04:43
09-22-2024 04:43
Hi there, @bessad. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still stuck on the Fitbit logo. I understand your concern, I will do my best to help you with this!
Since your Versa 2 is still stuck on the Fitbit logo, please try the following steps in the order listed while your Versa 2 is connected to the charging cable:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
