Versa 2 won't receive text messages from my S20
ANSWERED
I am receiving calls but unable to get text messages from my Galaxy s20 anymore. Notifications are on, I've turned off Bluetooth to re-sync, restarted phone and Versa2.
1 BEST ANSWER
Accepted Solutions
Hi @Robbins23  -  just on the off chance pull down the from the top of the watch face twice and tap on the 2 white bars to get to Quick Settings and check Sleep or Do not disturb icons are greyed out. Also check do not disturb on phone and volume is not silent perhaps.
6 REPLIES 6
Hi there, @Robbins23. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Would you mind checking if the following is enabled on your phone? Open the Message+ app, then go to "Settings", then "Notifications", then "In-app notification settings", then enable "Preview new messages".
If the above wasn't enable, try enabling it and then test your notifications to see if they can be open the way it's expected.
That was already enabled. I turned it off and then back on. Still no luck.
Thanks. Those were already grayed out.
Was Fitbit or the forums ever able to help you?  I am having the same problem and was hoping you were able to resolve this issue.
Hi @mesport  - does the best answer in this post not work for you?
What other things have you tried?
