08-10-2020
22:31
09:40
08-10-2020
22:31
09:40
my sleep start tome is inaccurate often. No longer able to edit it in app. Only brings up sleep stop time.
When I edit it, shows all zeros for start time. Uninstalled and reinstalled app, have current updates...
08-11-2020 09:46 - edited 06-25-2024 08:41
Hi there @btasy, welcome to the Community Forums. Thanks for letting me know that your Versa 2 doesn't track your sleep data accurately. I appreciate the details shared in your post and your time and efforts in trying to fix this issue, I'll be glad to continue assisting you.
As a first approach, I'd like you to please confirm that the heart rate settings on your watch is "On". On your device, open the Settings app > Heart Rate > tap to turn the setting On.
On the other hand, I recommend considering the following in order to get sleep stages:
About the edit option not working, would you mind letting me know if you've followed the directions on how to do so as described here: How do I add, edit, or delete Fitbit data and activities?
I'm looking forward to you response, keep me posted.
Best Answer08-11-2020 15:46
08-11-2020 15:46
Lost sleep data and does not show graph anymore
Best Answer08-13-2020 06:19 - edited 10-03-2023 09:59
Hi there @RuthAnn46, welcome on board. As per the description of your post it seems that your Versa may be not paired anymore to your Fitbit account and that's why the sleep data and sleep graph were gone.
To see when was the last time sync or if your Versa is paired, tap the Today tab > your profile picture > your device image.
If your watch is unpaired, please set it up again by following the steps at: How do I set up my Fitbit device?. On the other hand, if your watch has not recently synced, follow these troubleshooting steps: Why won't my Fitbit device sync?
Also, please make sure to check and follow the tips and recommendations I provided here to make sure you receive your sleep data.
