02-28-2023
11:14
06:22
02-28-2023
11:14
06:22
It will not respond after reset. I followed the steps listed elsewhere to unpair from my phone, turn off blue tooth, turn off phone, turn phone on, turn blue tooth on and try to pair. It will not work still.
03-02-2023 06:28 - edited 03-22-2024 08:40
Hi there, @Anm52601. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. So, as @Guy_ recommended, I suggest following the steps below in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues updating your Fitbit device, see Why can't I update my Fitbit device?
Hi there, @JojoKerry6. Thanks for stopping by in the Community Forums. I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
I hope we can get you back on track soon.
02:11
08:32
03-02-2023
02:11
08:32
Hi @Anm52601 - if you did a factory reset you will need to start afresh.
Remove the Bluetooth entry from the phone.
Logout of the Fitbit App and swipe off the active window
Restart the phone
Login to the Fitbit App and click profile photo and then " + Set up a Device" and replace and sync. This is look for the watch and create a new Bluetooth entry.
03-02-2023 03:56
03-02-2023 03:56
Same issue here with mine
Best Answer03-02-2023 06:28 - edited 03-22-2024 08:40
Best Answer03-02-2023 07:13
03-02-2023 07:13
03-02-2023 07:13
03-02-2023 07:13
The Support Team have not come back to me???
03-02-2023 07:52
03-02-2023 07:52
Same with me- is it connected to the large issue going on with the app?
