02-03-2022
02:53
03:50
02-03-2022
02:53
03:50
Watch can no longer sync. Red x saying it does not connect and to reboot, but still will not charge or turn on
02-03-2022 03:53 - edited 08-24-2023 04:12
Hi there, @Caitlinscott. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
If you haven't done so yet, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer02-03-2022 03:53 - edited 08-24-2023 04:12
