04-26-2022
12:57
14:00
04-26-2022
12:57
14:00
3 days ago my versa 2 has stopped working, battery was at 65% when it shut itself down while I was swimming.
I have followed all the instructions of holding button in, but it wont restart at all.
I have put it on the charger overnight and still nothing.
I am really disappointed with this, as it is the 2nd versa I have had since 2019 with the same problem. I am away from home on holiday at the moment and as email support no longer available thought I would try here. Suggestions most welcome. It is unlikely that I would purchase a fit bit again after this.
04-26-2022 14:02 - edited 02-20-2024 03:10
Hi there, @PMJ65. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
If you haven't done so yet, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
If none of the above works, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
04-26-2022 16:01
04-26-2022 16:01
Hi there, there is absolutely no power at all in my versa2 at all so none of the above mentioned suggestions work.
