07-30-2022
08:41
14:52
07-30-2022
08:41
14:52
Yesterday my screen went off on my Versa 2 and was only able to access a few random times. So I reset. I think! I selected reset but not sure this was carried through. Now my Fitbit hasn’t charged. Can’t sync now and nothing showing on screen
07-30-2022 14:53 - edited 11-16-2023 11:14
Hi there, @Geisland. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
If you haven't done so yet, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
Best Answer07-30-2022 14:53 - edited 11-16-2023 11:14
Hope that helps.
