02-04-2023
17:49
07:06
02-04-2023
17:49
07:06
My versa 2 has locked up no clock face or, will not sync fed up with problems.
02-06-2023 07:08 - edited 03-09-2024 05:47
Hi there, @wireman. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out. I understand how you must be feeling.
If you haven't done so yet, I'd suggest trying the following steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
@Guy_ Thanks for helping out!
02-04-2023
20:38
05:47
02-04-2023
20:38
05:47
Hi @wireman - first check there are lights flashing on the back, if not try charging it. If it gets hot stop immediately.
If lights are flashing double tap the screen and if no display press and hold the button for 12 seconds, till it vibrates and hopefully logo appears.
