07-04-2021
14:14
09:21
07-04-2021
14:14
09:21
So I haven't been using my Versa 2 for a while and wanted to get back to using it. I tried to sync with my phone, but it wouldn't work. I tried all the troubleshooting steps but it didn't help, so I went to factory reset. Now it won't set up at all, it doesn't "find" my device. Twice I got the "found it!" message, but then it went back to the "make sure your Versa 2 is on" screen. I've rebooted my phone and my watch multiple times. I've reinstalled the app and made sure it's up to date. I've made sure my phone (Huawei P30 lite) is up to date. I even made a new fitbit account, but it still won't work. Help!
07-05-2021 09:23
07-05-2021 09:23
Hi there, @RisuN. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Please note that the difficulty you are having to set up your Versa 2 usually happens when you perform a factory reset without first unpairing the watch. So, in order to solve this issue, I'd recommend trying the steps below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Best Answer07-07-2021 05:41
07-07-2021 05:41
I also have the same exact issue and went through these steps multiple times and still nothing. It shows a red X and says data not cleared, sync and try again.
Best Answer07-07-2021 05:58
07-07-2021 05:58
Hi there, @Acasper427. Thanks for stopping by and following the troubleshooting steps I provided above.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer07-12-2021 09:12
07-12-2021 09:12
So, I have no idea what happened. My Versa was on the charger on my desk when I suddenly got a notification to set it up on my phone, without me doing anything. I continued with the setup and it now works perfectly. I have no idea why, but I guess the problem solved itself.
Best Answer07-12-2021 11:06 - edited 03-20-2024 10:46
@RisuN Awesome! I'm very glad to hear that you could set up your Versa 2. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
