03-08-2021
00:57
18:15
RicardoFitbit
03-08-2021
00:57
18:15
RicardoFitbit
My Versa 2 has lost time and now won't show up on my Bluetooth list , to sync with my phone. I have shut it off and turned it back on multiple times. A few times, it wouldn't sync with the Fitbit app, but now it is. Ugh!
03-08-2021 02:16
03-08-2021 02:16
Generally its not an issue if it doesn't show in Bluetooth, the Fitbit App handles it
Try Bluetooth issues - made simple Android 3.39.2
If the only way to get a Bluetooth connection from the watch is to restart it, it may have a problem.
As regards the time loss. If it doesn't sync it may lose a little time over days. If it loses more than that there may also be another issue.
Try changing the clock face to a standard Fitbit one, if the problem persists the watch may have a fault.
In which case its probably best to contact Fitbit Support directly. They may be able to help you.
