04-06-2022 05:22 - last edited on 04-07-2022 13:09 by MarreFitbit
I recently traveled to a different time zone and back, but my versa is not changing times. I've synced it, uninstalled and reinstalled it, but to no avail. It's becoming quite irritating. Help!
04-07-2022 13:10 - edited 11-13-2023 04:30
Hi there, @pumpkinnose13. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand how you must be feeling.
Note that the time on your Fitbit Versa 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
Hope that helps.
Hope that helps.
