Versa 2 won't show the correct time after traveling
ANSWERED
The time on my Versa 2 is different than that on my phone. I can't seem to figure out how to get it to sync. It all started when I changed time zones. Now it won't change back.
1 BEST ANSWER
Accepted Solutions
Hi there, @Kpbooster. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Note that the time on your Fitbit Versa 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
Hope that helps.
4 REPLIES 4
Hi @Kpbooster -  in the Fitbit App, App settings disable automatic Time Zone, sync, then reenable and sync again.
If that doesn't work select the Time Zone manually.
Hope that helps.
This is a daylight savings time issue
thanks for the response
Hi there, @Westini. Welcome on board. Anytime! 🙂 I'm glad to hear that the steps worked for you.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
