Versa 2 won't show the correct time after traveling
After travelling and changing time zones, my watch won't change back and match Phone
4 REPLIES 4
Same issue. Any change?
Hi there, @Jackpot29 @Songbird102. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Versa 2 devices are showing the wrong time. I will do my best to help you with this.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your Fitbit device has recently synced, go to your Fitbit app and tap the Today tab, and then tap Devices. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
If by any chance you're facing syncing difficulties, please see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Versa 2 is syncing, please try changing your time zone to a completely different one, sync your device, put the correct time and sync again.
In the Fitbit App
Turn Automatic Time Zone OFF and then Back ON...
That should do it
In the Fitbit App
That should do it
