03-15-2023
11:44
08:50
03-15-2023
11:44
08:50
This is the second versa that after 2 years just won’t show time and sync. The first time the red light on the back burned my wrist! Before it gets to this point, is there a fix?
03-16-2023 08:51 - edited 06-03-2023 11:13
Hi there, @Walkingva. Welcome to the Community Forums and sharing the details about the issue with your Versa 2. I understand how you must be feeling.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
