06-14-2021
15:55
08:30
06-14-2021
15:55
08:30
I have had my fitbit versa 2 for about a year and a half. And have constantly had connection issues... I have tried uninstalling the app. I have tried shutting my phone down. Turning off my fitbit... it connects and then drops again... this has been a constant issue... do you have any suggestions that I haven't tried? Oh- and I always check for updates. I know that is important, also. Any and all help would be appreciated. Thank you
06-15-2021 08:32 - edited 01-02-2024 05:17
Hi there, @Cowlover93. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
As a first approach, please make sure that your Galaxy Note 10 meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope that helps.
Best Answer06-15-2021 08:32 - edited 01-02-2024 05:17
Hope that helps.
