09-24-2021
12:45
19:12
09-24-2021
12:45
19:12
what can I do when my watch doesn't want to update it works fine for awhile then does it and so far the only way had been remove watch then save it again start all over.Is there a better way to get your watch to sync
09-27-2021 06:04 - edited 03-03-2024 03:38
@dbull988 If you're getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
I'd like to provide the following steps that actually work for Huawei users, I know you have a LG stylish 4, but it's still and Android device, so I thing it would worth the try:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
Hope that does the trick for you too.
09-24-2021 19:27
09-24-2021 19:27
Hi there, @dbull988. Welcome to the Community Forums. Thanks for trying to troubleshoot the inconvenience with your Versa 2 before reaching out. I understand where your concern is coming from.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below in the following order:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope that helps.
Best Answer09-25-2021 10:35
09-25-2021 10:35
I have an lg stylis 4 it's old but not that old lol is there any secret tricks or anything it sucks having to reset everything everytime it wants to be wonky
Best Answer09-27-2021 06:04 - edited 03-03-2024 03:38
09-27-2021 07:07
09-27-2021 07:07
Best Answer09-27-2021 08:23
09-27-2021 08:23
@dbull988 Sure! 🙂
Best Answer09-27-2021 08:50
09-27-2021 08:50
I was having trouble with this exact thing. The only notifications that were coming through were phone calls. Just followed your above steps, and IT'S WORKING. All notifications coming through. Thank you kindly. For reference, I have a Huawei Nova 5t. Can't thank you enough 👍🏻😎
09-30-2021 03:38
09-30-2021 03:38
I have had my versa 1 days and it is showing the notification message. However the steos above do jot apply to my Huawei p30. Very annoyed that its is not working after 1 day!!
Best Answer09-30-2021 03:53
09-30-2021 03:53
My phone settings were slightly different to the a I've steps.
I've rechecked my version if the steps, and I've got these steps for you to try 😊
> settings
> apps
> apps (again)
> fitbit
> power usage details
> launch settings
> TURN OFF "manage automatically"
> under this option there are 3 options, make sure they are ALL TURNED ON
+ auto launch
+ secondary launch
+ run in background
Caps isn't yelling at you by the way. Restart phone and fitbit if necessary. Hold down button on fitbit until the logo comes back up. Go back into fitbit app and see if the message of "not working" is gone.
Hope that helps
