02-21-2021
02:47
04:52
02-21-2021
02:47
04:52
I have had trouble with my versa 2 staying sync
What can I do. I have turned phone off and on also turned bluetooth on and off. This is frustrating
02-22-2021 04:53 - edited 09-08-2023 09:35
Hi there @Evaseal, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand how frustrating this can be.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If you haven't done so, please see Why won't my Fitbit device sync?
If you have tried the above with no avail and your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try what @Guy_ has suggested you or you can also try the following:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
02-21-2021 06:13
02-21-2021 06:13
Try disabling power saving
On the phone check battery optimizations [the options may be different in your version]
On IOS uninstall/reinstall the Fitbit App, and redo the setup fo your notifications.
