01-16-2022
14:17
10:28
01-16-2022
14:17
10:28
My Versa 2 will not connect to wifi or app. This is an issue at least every other week. I spend more time trying to fix it then I do charging it.
01-17-2022 10:31 - edited 03-15-2024 16:12
Hi there, @Nala0325. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2. I understand where your concern is coming from.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa 2 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If you continue having issues, please see Why won't my Fitbit device sync?
As for the Wi-Fi issue, see Why won't my Fitbit watch connect to Wi-Fi?
01-18-2022 13:10
01-18-2022 13:10
I have a similar experience, however my device doesn't sync and doesn't recognize the fact. The workaround options are not applicable. Attempting to reset the device over Bluetooth or wi-fi also unsuccessful.
