01-19-2024 08:10
01-19-2024 08:10
An issue that I’m having is on top of not being able to swipe from the clock face Home Screen is that it won’t even display the home screen sometimes. When I go to look at the time it is just a black screen, and pressing the left button sometimes doesn’t turn it on either. Then a few minutes later it will work again. I’m not sure what can be done as I have tried turning it off, and doing factory resets. It also randomly vibrates on my wrist for no reason? Pleas help as I would miss not having it!
01-19-2024 23:25
01-19-2024 23:25
Hi @Tigni - it sounds like the watch may have a fault but to make sure.
If you can wake the display and pull down on the watch face once, then again and tap on the 2 white bars to get to Quick Settings and turn on Always On.
Then see if the screen goes off at any point when it's not showing your chosen clock face. If should remain on [except at night in Sleep mode].
You could try changing the clock face you are using if you reinstalled it after the factory reset as that may be causing an issue.
When you turn off the Always On mode make sure to turn off Sleep and turn on Wrist wake.
If you can't get to Quick Settings, in the Fitbit App turn on Quick view and sync, the watch should display when you look at it or push the button.
01-20-2024 12:13
01-20-2024 12:13
I have the same issue, started 3 days ago when it dropped in the middle of a workout and went black screen, then the logo shows up and it goes back to the clock face but it's also going little intermittent vibrates for no reason. I've tried everything, including a full factory reset and nothing has helped.
01-20-2024 12:14
01-20-2024 12:14
I have the same issue, unfortunately the steps above have not helped it and it persists
