10-05-2019
13:10
06:57
AlejandraFitbit
10-05-2019
13:10
06:57
AlejandraFitbit
I can see the home screen on my Versa 2 but can’t do anything from there. On the rare occasion I can get it to move to another page, I can’t get anything to work when I touch an icon. I’ve restarted it multiple times and charged it to see if either of those would help but nothing changed.
02-25-2020 16:58
02-25-2020 16:58
Best Answer02-25-2020 18:00
02-25-2020 18:00
Best Answer02-25-2020 18:13
02-25-2020 18:13
Best Answer02-26-2020 07:23 - edited 02-26-2020 09:10
I think the problem was solved now after the new update .. or
Best Answer02-26-2020 09:34
02-26-2020 09:34
Best Answer02-26-2020 10:06
02-26-2020 10:06
My Versa 2 was replaced about 2 monthes ago after 1 month. But the second one do have the same problem. I bought the first one on 25 november 2019 and that one is replaced on 24 december 2019. The second one broke 24 febr 2020. Is it a bad watch or (I hope) bad software.
Best Answer02-28-2020 16:06
02-28-2020 16:06
Hello i have same problem my fitbit versa 2 doesn't work the swipping. Please help to resolve mine.
Best Answer02-28-2020 16:10
02-28-2020 16:10
My fitbit its just only gift. The bought it in Florida. I been using my watch fibit its been only two months. Then now i can swipe it off. Its make me crazy to fix this. Its that possible can you replace it. But I dont have the bill.
Best Answer03-05-2020 03:30
03-05-2020 03:30
I am having the same issues. I've tried restarting it multiple times. It's so frustrating since I've only had it a couple months!
Best Answer03-05-2020 05:40
03-05-2020 05:40
I am having the same problem. I have downloaded the new firmware. I have restarted it multiple times using the back button. I have fully charged it. The problem is intermittent but it is growing worse each day. I try to swipe and nothing happens.
Best Answer03-05-2020 05:46
03-05-2020 05:46
I think everyone should call Fitbit support and complain because this is turning out to be a much wider spread issue then they lead me to believe and it must be something wrong with the product/ software.
03-05-2020 05:46
Change the Screen Wake option to Manual. It appears the Auto Wake option is bugged. After I changed it to manual it's been working great. If I try to change it back to Auto Wake it will freeze again.
Best Answer03-05-2020 07:19
03-05-2020 07:19
Best Answer03-05-2020 07:25
03-05-2020 07:25
After the watch freezes do a reboot. Hold the button on the left of the watch for about 10 seconds. During the reboot you will see the fitbit logo. Upon rebooting immediately go to settings. "Normally" the watch will work after a reboot, but will freeze again if the watch goes into sleep mode if you dokt quickly change the settings.
Best Answer03-05-2020 07:29
03-05-2020 07:29
I've got a new replacement. Support was perfect and quick. The replacement within about 5 days.
Happy 😀
Best Answer03-05-2020 07:40
03-05-2020 07:40
I am having the same issue, and have been trying to live chat with a FitBit representative for the last half hour and have been unable to reach anyone. Please Help!
Best Answer03-05-2020 08:04
03-05-2020 08:04
I called them on the phone rather than live chat. Whenever I chat they always make me switch to a call anyways
Best Answer03-05-2020 08:05
03-05-2020 08:05
I sent mine back using the postage they supplied and it took literally 2 weeks to get to them. I’m really annoyed.
Best Answer03-05-2020 08:17 - edited 03-06-2020 08:27
The email with PDF shipping label does not work. This is the address
they said to send your watch, bands, and charger to get instructions to get
a replacement:
Ingram Micro Mobility
501 Airtech Pkwy
Plainfield, IN 46168
Track the shipment and let Fitbit support know the tracking number with the case number they give you. I have low hopes getting this fixed or getting replacement easily in a timely manner, but only time will tell. If I had to choose fitbit again, I may not. It depends if Google buys it and how they fix these issues. Swipe not working with no way to get to the settings to reset or change always to always on is a deal-breaker.
Best Answer03-05-2020 09:26
03-05-2020 09:26
