10-22-2021
05:54
08:29
DavideFitbit
10-22-2021
05:54
08:29
DavideFitbit
After doing an update on my phone 3 days ago, my Versa 2 now won't sync and I get no notifications on my watch.
Moderator edit: format
10-22-2021 08:28 - edited 10-22-2021 08:28
Hi, welcome to the Fitbit Community forums, @SunsetRunner.
Thank you for sharing this information about the trouble you've been having with your Versa 2 watch.
Before considering other options, could you please confirm if you already tried all the steps listed here to resolve syncing problems? In addition, make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
Regarding the inconvenience to receive notifications, make sure to follow all the steps listed in this article. Keep in mind that you need Android OS 8.0 or higher or Apple iOS 13 or higher on your phone and that you won’t see notifications on your Fitbit device if you turned on the Do Not disturb Icon or Sleep Mode.
Hope this helps, I'll be around.
Best Answer10-22-2021 14:03
10-22-2021 14:03
Best Answer10-23-2021 06:29
10-23-2021 06:29
Try removing the watch from your account using the fitbit app on your phone and re-installing it, this fixed my issues - good luck!
10-29-2021 18:03
10-29-2021 18:03
@SunsetRunner Thank you for your reply and confirming that you already tried all the suggested troubleshooting steps.
In this case, I recommend that you get in touch with the Customer Support team for further assistance with this. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a great day.
Best Answer10-29-2021 18:24
10-29-2021 18:24
That worked for me.
10-29-2021 23:41
10-29-2021 23:41
Thank you for your help. I have finally got it working. I was persistent and everyday I followed the steps for days. Then eventually it worked!
10-30-2021 05:32
10-30-2021 05:32
11-09-2021 17:25
