Versa 2 won't sync or pair again with my phone
ANSWERED
Versa 2 stopped syncing so unpaired it. Trying to pair it again and device isn't picked up via Bluetooth by phone or fitbit app.
1 BEST ANSWER
Accepted Solutions
Hi there, @Aepc71. Welcome to the Community Forums. Thanks for the details provided about the issue with your Versa 2. @Odyssey13 Thank you so much for your help!
I seems like you've either removed your Versa 2 from your Fitbit account or performed a factory reset, haven't you? If that is the case, please follow the steps below:
  • Remove your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2 once again.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
2 REPLIES 2
see this article for some helpful troubleshooting - click to go there.
Stepping in the U.S.A. since September 2013. Android 14
Hope that helps.
