10-08-2022
03:40
04:08
10-08-2022
03:40
04:08
Hi, My fitbit isn't displaying steps. Due to a phone issue with my cell phone, yesterday I needed to borrow my daughter's phone and set up the fitbit app on that. I thought it was set up correctly, but now my fitbit isn't showing steps, instead it says undefined.
Help? I need it to track my steps as I'm in a stepbet marathon (3 of them, actually) and don't want to lose my bets. I've got to get this fixed today.
10-08-2022 04:11 - edited 11-21-2023 05:14
Hello there, @helaurin. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 2. I understand where your concern is coming from.
It seems that your Fitbit device cannot connect properly to your daughter's phone since you haven't yet forgotten the connection between your Fitbit device and your phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
Hope that helps.
Best Answer10-08-2022 04:11 - edited 11-21-2023 05:14
Hope that helps.
Best Answer10-08-2022 06:40
10-08-2022 06:40
Best Answer10-08-2022 08:46
10-08-2022 08:46
@helaurin Sure thing! I'll be around if you need further help. 🙂
