06-06-2022
07:16
07:23
06-06-2022
07:16
07:23
I have to reset my Versa 2 every time I want it to sync, and it takes several minutes for it to work. Is there a way to fix this? I have an Android phone.
06-06-2022 07:23 - edited 11-14-2023 08:59
Hi there, @Scorpio13714. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try what @Guy_ has suggested you or you can also try the following:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope that helps.
Best Answer06-06-2022 07:23 - edited 11-14-2023 08:59
Hope that helps.
