05-01-2021
04:17
08:16
05-01-2021
04:17
08:16
My fitbit is not syncing with my Galaxy S9, it was performing with no issues, but now it won't sync. I uninstalled, and reinstalled the app, tthree times, check the device settings and made sure I gave permission to allow Fitbit, blue tooth is on, and paired to versa. Every time I finally got it to repair and sync; the same issue happens again.
05-01-2021 08:22
05-01-2021 08:22
Check you battery saving setup on the phone, it should work well on this phone
On the phone check battery optimizations [the options may be different in your version]
The same Android clear cache and force stop are a good way to resolve most issues [sometimes a logout too], saves a lot of fiddling about.
Occasionally a restart of both watch and phone restores things.
Note this Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones].
05-03-2021 08:15 - edited 03-18-2024 09:55
Hi there, @Stormmoon25. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've performed so far and @Guy_'s suggestions, I'd recommend trying to following:
1. Remove the Versa 2 from your phone's Bluetooth settings and the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
By the way, I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope that helps.
05-03-2021 08:30
05-03-2021 08:30
05-03-2021 09:36 - edited 09-05-2023 09:46
@Stormmoon25 Awesome! I'm glad to hear you're back on track now. 😊
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
