11-16-2020 02:51 - last edited on 11-16-2020 08:54 by MarreFitbit
My Versa 2 will not connect to my iPhone 12. Is this a none issue and if so will it be fixed soon?
11-16-2020 08:56 - edited 01-08-2024 05:14
Hi there @LouiseK68, it's nice to see you around the Community Forums. I'm sorry to hear that your Versa 2 isn't syncing to your iPhone 12, I understand where your concern is coming from. I'll be glad to help you.
If you haven't done so yet, please follow the troubleshooting steps provided here: Why won't my Fitbit device sync?
Please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher, Android OS 7.0 or higher, and Windows 10 version 1607.0 or higher. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit app, and are constantly working to confirm compatibility with new phone models. Be sure to verify that your phone or tablet meets the minimum operating system requirements.
Let me know how it goes.
11-16-2020 11:29
11-16-2020 11:29
Make sure that after you set up your new phone to turn off Bluetooth on your old phone. Then try to sync on your new phone.
11-18-2020 02:04
11-18-2020 02:04
Thank you. Read the above response from the moderator clicked all the links, read all the information, searched some more, then found your response.
Fixed my connection issue to my iPhone 12 in two seconds.
Thank you sooooo much !
01-04-2021 17:10
01-04-2021 17:10
I’m having this problem but I don’t have access to my old phone. I’m about ready to give up on Fitbit. It shouldn’t be this difficult. I’m very frustrated. 😤
01-04-2021 17:56
01-04-2021 17:56
Have you tried deleting your Fitbit and reinstalling on your iPhone 12? Just trying to help you as I feel your frustration!
04-15-2021 20:30
04-15-2021 20:30
Thank you. Same as NessieC...I went through all the steps. Then found your comments and fixed it quickly. I was starting to think I needed to get an Apple Watch.
04-16-2021 05:49
04-16-2021 05:49
08-06-2021 07:05
08-06-2021 07:05
I know exactly how you feel. I’ve gone through the troubleshooting several times and every morning the same problem. It’s fine on the app on my iPad but every time I try to sync on my phone no joy. This happens every time I get a new phone. Think it’s time to go over to the Apple Watch so at least I’ll know for sure they’re compatible and won’t waste days of my life feeling frustrated.
02-27-2022 23:04
02-27-2022 23:04
Like you I don’t have access to my old phone,getting fed up with it all now.
