07-16-2021
14:50
17:13
07-16-2021
14:50
17:13
Updated my phone software, and now I can't connect to my fitbit. (I've tried restarting everything and unadding bluetooth)
It says the last time I synced it was 2 weeks ago, and the app says it still has no charge.
The watch itself is chugging along at 34%. It even shows up in available Bluetooth connections in Android menu.
What can I do? There isn't a fitbit app update, so I dont know what I'm missing
07-16-2021 17:14 - edited 10-22-2023 04:12
Hi there, @Disc. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the following steps:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
Hope that helps.
Best Answer07-16-2021 17:14 - edited 10-22-2023 04:12
Hope that helps.
