Versa 2 won't sync to my phone anymore
ANSWERED
Versa 2 no longer syncs with my phone tried to reload and now my phone no longer recognizes it
1 BEST ANSWER
Accepted Solutions
Hi there, @arleenfuller. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. @SunsetRunner Thanks for trying to help!
In addition to the steps you've done so far, please try the following:
  • Unpair your Versa 2 from your phone's Bluetooth settings and also from the Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
2 REPLIES 2
Hello @arleenfuller
When you say reload do you mean reinstall the Fitbit App or do you mean you restarted your Versa 2? Please clarify so I can help 😃
