04-01-2021
20:01
04:47
04-01-2021
20:01
04:47
My versa battery died. When I charged it and turned it back on it won’t synch to the app. It is showing it is connected to Bluetooth but I can’t get the app to sync so the time is off in my watch and I’m not getting notifications.
04-02-2021 04:48 - edited 12-15-2023 10:03
@Natrae It's nice to see you around the Community Forums.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa 2 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If your watch is still not syncing after following the above steps, see Why won't my Fitbit device sync?
Hope that helps.
Best Answer04-02-2021 04:48 - edited 12-15-2023 10:03
Hope that helps.
