03-29-2022
08:44
13:49
03-29-2022
08:44
13:49
Hiya
The watch is not continuously syncing and I am having to manually re sync on the app. Using the watch as a continuous glucose monitor so would ideally be transmitting the data every five minutes. I have reset everything and still no luck.
Thanks
03-31-2022 13:50 - edited 10-07-2024 11:17
Hi there, @HebeHems. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
