02-17-2022
16:50
06:09
02-17-2022
16:50
06:09
I just got my Versa 2 and the heart rate doesn’t work. I try to bring it up and it doesn’t say anything and is grayed out on the watch.
02-17-2022 20:05
02-17-2022 20:05
Hi @BlazeOfGlory99 - did you try going into watch Settings and check Herat rate is turned on?
02-17-2022 21:35
02-17-2022 21:35
02-18-2022 06:11 - edited 12-26-2023 08:26
Hi there, @BlazeOfGlory99. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2.
As with all heart-rate tracking technology, accuracy is affected by personal physiology, device location on your arm, and type of movement. For a more accurate heart-rate reading:
During exercise, wear your device a bit tighter and higher for an improved fit. The band should be snug but not constricting (a tight band restricts blood flow, potentially affecting the heart-rate signal). Many exercises such as bike riding or weight lifting cause you to bend your wrist frequently, which could interfere with the heart-rate signal if the watch is lower on your wrist.
To resolve common issues, make sure you've followed our troubleshooting steps in What factors can affect my heart-rate reading on my Fitbit device?
Hope this helps.
02-18-2022 06:18
02-18-2022 06:18
