04-10-2023
08:06
10:41
04-10-2023
08:06
10:41
Hi
i have followed all instructions to set up but the skin temperature and oxygen saturation has not down loaded.
has anyone had the same problem? Thanks
04-10-2023 10:42 - edited 03-17-2024 05:52
Hi there, @Sengul18. Thanks for stopping by in the Fitbit Community Forums and sharing the details about the issue with your Versa 2.
Please note that you need to wear your Versa 2 for three days before you start seeing values.
Factors that may cause skin temperature to vary nightly include changes in room temperature, bedding, circadian rhythm, menstrual cycle, or the potential onset of fever.
Note: Significant changes in ambient temperature may negatively impact skin temperature tracking. For more information see, How can Fitbit help me track my temperature?
Regarding SpO2, keep the following in mind to make sure your Fitbit device successfully measures your SpO2 values:
Turning off any clock face permissions can cause the clock face to stop functioning. To check these settings:
Your Fitbit device must be able to consistently track your SpO2 data:
Wear your device slightly higher on your wrist.
Make sure your device is in contact with your skin.
Your device should be snug but not constricting.
Tattooed skin can impact the accuracy of the red and infrared sensors on your Fitbit device.
For more information about SpO2, see: How do I track blood oxygen saturation (SpO2) with my Fitbit device?
Best Answer04-10-2023 10:42 - edited 03-17-2024 05:52
Best Answer04-12-2023 01:35
04-12-2023 01:35
