Versa 2 won't track my sleep data accurately
ANSWERED
i see many posts about sleep tracking. My Versa 2 is not consistent in tracking my sleep. It usually tracks 5 to 6 days a week but not every day. Also, some days it tracks only part of the night. Some nights it shows maybe 3 hours of sleep while I did get 6 to 7 hours. I have a sleep disorder and wear a CPAP to help with my sleep. Any updates I can do to get better tracking results?
1 BEST ANSWER
Accepted Solutions
Hi there, @Lionbill. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your sleep data.
I recommend considering the following in order to get sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
4 REPLIES 4
If you fall back to sleep, the extra hours are not added. Any solution?
I’ve done all your suggestions and it still isn’t tracking accurately. It was accurate until a month ago. There’s no updates available
My Versa 2 has stopped recording my heart rate and tracking my sleep all of a sudden. I do not wear it loose and keep it charged regularly. What should I do?
Regards,
Mohan
