05-29-2022
12:16
07:24
05-29-2022
12:16
07:24
I just got a versa 2 to try ans fix my sleep syatus not getting tracked and recorded right on a charge 5 now its only tracking an hour or so and i dont knkw how to fix it any ideas
05-30-2022 08:07 - edited 11-14-2023 09:05
@GuardianSean Thank you for those details. I understand where your concern is coming from. Thanks for already trying moving your Versa 2 placement.
I'd recommend trying the following steps to make sure your heart rate is working:
Also, for more detailed information, see What factors can affect my heart-rate reading on my Fitbit device?
Additionally, I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
After following the steps above I will suggest testing your Versa 2 for the next 3 days and nights to see how it goes.
Keep me posted.
Best Answer05-30-2022 07:26 - edited 11-20-2023 13:20
Hi there, @GuardianSean. Thanks for stopping by in the Community Forums and sharing the details about the inconvenience with your new Versa 2.
Please note sleep stages are based on heart rate data. Since you just got the Versa 2, give the heart rate a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
For more information, see the following help articles
Hope this helps.
Best Answer05-30-2022 07:47 - edited 05-30-2022 07:49
Thats not the case for my wife she get her sleep data instantly. Mine has been this way since switching to the charge 5 it doesnt seem to sync right to the app i have to manualy add the log to get the correct data if im lucky it will record an hour or 2 or 2 periods of an hour or so not the whole night. I habe tried moving it up my wrist but nothing works.
Best Answer05-30-2022 08:07 - edited 11-14-2023 09:05
Keep me posted.
