01-15-2025
08:17
09:22
01-15-2025
08:17
09:22
My watch only tracks my sleep after midnight, although I go to sleep around 9 pm. How do I fix this? Thank you.
01-17-2025 11:23
01-17-2025 11:23
Hi there, @Ms1961. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Versa 2 is not tracking your sleep times accurately. I understand your concern, I will do my best to help you with this!
As a first approached, I'd recommend syncing your Versa 2 to the app after waking up. This will help to make sure that all your data is synced properly. Keep in mind that when your body is completely at rest and you haven’t moved for about an hour, your device records that you’re asleep.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
01-18-2025 05:30
01-18-2025 05:30
