Versa 2 won't track my sleep score
ANSWERED
I have had my versa 2 a long time. It has never tracked my sleep. I've tried all the suggestions. Wore it higher on wrist. Started it manually as well. But it never gives me a sleep score. It is all blank.
1 BEST ANSWER
Accepted Solutions
Hi there, @TruckaDoug. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Keep in mind that you must see sleep stages in order to see your sleep score information. Please swipe left on the Sleep Score graph, here you can see information about your weekly sleep average and sleep duration. To get more detailed information, see What's sleep score in the Fitbit app?
With that said, I recommend considering the following in order to get sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
Hope that helps.
1 REPLY 1
Hope that helps.
