09-30-2022
06:04
09:39
09-30-2022
06:04
09:39
Since the last Fitbit update, my sleep tracking is off. It will only track the first couple of hours. For example: I slept from 11:49pm last night until 7:27am this morning. Versa 2 only tracked from 11:49 to 2:33 this morning and said I was awake for 50 minutes. This inaccuracy has happened for at least two weeks. Any suggestions?
10-01-2022 09:43 - edited 03-15-2024 06:31
Hi there, @Briarbear. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 2.
As a first approached, I'd recommend to sync your Versa 2 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
If the above doesn't help, I'd recommend restarting your heart rate settings as sleep data is based on your heart rate readings. With that being said, I'd recommend trying the following steps to make sure your heart rate is working:
Please test your Fitbit device the next couple of nights and let me know if the issue persists.
Best Answer10-01-2022 09:43 - edited 03-15-2024 06:31
