02-16-2021 09:51
02-16-2021 09:51
My versa 2 was only bought at Christmas time and yesterday I wore it into the shower for the first time and now it won’t turn back on. I have tried all the suggested things. Dried it and tried to re charge it but it still won’t come back on.
02-16-2021 10:11
                              02-16-2021 10:11
Hi @TrishB973 do you see any moisture in the device? Usually if it's gotten soaked, putting it in a dry bowl of rice for 48 hours is suggested before you charge it. Also, clean all the connector points and restart it if possible.
 Best Answer02-16-2021 10:20
                              02-16-2021 10:20
It is unlikely the Versa 2 is suffering water damage in such a short time, but can't be ruled out.
When you charge it does it get hot, if so then there is a problem and it may need time to dry out inside, probably not the issue though.
Check the restart the watch with the button procedure to make sure you got it right.
02-16-2021 10:20
 Best Answer02-16-2021 10:25
02-16-2021 10:25
 Best Answer02-16-2021 10:26
                              02-16-2021 10:26
@TrishB973 I've asked a moderator to stop by to assist you.
02-16-2021 10:30
02-16-2021 10:30
		12:28
		09:55
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		02-16-2021
		12:28
		09:55
@Odyssey13 Thanks for your assistance on the thread.
@Guy_ Thanks for stopping by.
@TrishB973 Hi there. Thanks for the details mentioned and the troubleshooting tried. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Have a nice day.
