Versa 2 won't turn on or charge
ANSWERED
My watch will act like it is getting ready to start up but it come on for a second and goes right back off and it won’t charge ! Help
1 BEST ANSWER
Accepted Solutions
Hi there, @TawniaC. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 2.
As a first approach, I'd recommend restarting your Versa 2. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work and your Versa 2 does not vibrate while trying to perform the restart, please make sure you've followed all the steps provided below:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
1 REPLY 1
