04-07-2022 14:29 - last edited on 04-08-2022 05:11 by MarreFitbit
Fitbit versa will not turn on. When I hold the bottom I get red (!)
04-08-2022 05:13 - edited 11-13-2023 04:27
Hi there, @Mamadog1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Did your Versa 2 vibrate while you tried performing the restart? If it didn't, I'd suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
04-07-2022 22:53
Hope that helps.
04-08-2022 05:18
04-08-2022 05:18
04-08-2022 05:37 - edited 07-17-2023 04:11
@Mamadog1 Awesome! I'm glad to hear that you managed to solve the issue. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
