11-27-2022
12:26
15:29
11-27-2022
12:26
15:29
I had my versa2 for just over 2 years
Today just turned off and won't work. I've tried to restart it but still won't work also not charging .
11-27-2022 20:11
11-27-2022 20:11
Hi @Ioanav2 - did it by any chance get wet at some point?
You can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support. they may attempt a factory reset if there is any charge left.
The good news if you can't revive it is a new one should be available at a reduced price. Don't go for a more expensive one.
11-28-2022 15:31 - edited 08-04-2023 03:39
Hi there, @Ioanav2. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done so far, I'd suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
If none of the above works, please follow @Guy_'s advice.
11-28-2022 16:33
11-28-2022 16:33
I have this same issue.. It just all of the sudden stopped working and charging, they're trying to get me to buy a new one. mines barley a year old
11-28-2022
19:38
11:37
11-28-2022
19:38
11:37
Hi @Ahsha - it could be a screen fault, to verify go to the Fitbit App and check when it last synced and if you can still sync.
A new one may be on offer in the shops if you can't fix it.
Either way in the app, make a note of which clocks and apps you have installed to make it easier to set up a new one.
