Versa 2 won't turn on or charge
Hi,
So today after I came out of the shower. My Fitbit suddenly wouldn’t not turn on. I then did the power method by holding the power button until the logo appears and tried this several times but the logo wouldn’t appear. I’ve also noticed the green LED light isn’t flashing on the back of the watch.
I then tried charging it but after 5 minutes nothing seemed to change so I left it for an hour and still nothing seemed to change.
I have tried cleaning the watch as well. But it also looks like that hasn’t worked.
1 REPLY 1
Hi @Rohan.bhoobun  - unfortunately the watch got water in it. It isn't recommended to be used with hot water, some seals are very fragile.
Fortunately if it's not under warranty a new one is most likely available at reduced price these days. Don't go for a more expensive one.
