12-26-2022
23:49
04:14
12-26-2022
23:49
04:14
My Fitbit has died and won’t charge or turn on. I have tried to reset with no luck. It hasn’t synced since 3rd December
12-27-2022 04:16
12-27-2022 04:16
Hi there, @Lisamwig. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest trying the below steps:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope that helps.
12-27-2022 04:16
12-27-2022 04:16
Hope that helps.
01-01-2023 12:05
01-01-2023 12:05
Hi MarreFitbit,
my watch doesn’t respond to any of the steps offered to Lisa. I appreciate my FitBit is out of warranty, but there should be a way to reset it.
I was offered 35% discount if purchasing a new replacement back in October 22, but I was out of the country until recently and didn’t have access to my mailbox.
surely FB must have a way to reset the watch,
