06-15-2023
14:11
04:01
06-15-2023
14:11
04:01
My versa stopped responding to swipes and stopped charging with my charger then died. I cleaned the connectors got a little connection then screen went black. It is completed unresponsive now.
06-16-2023 04:04
06-16-2023 04:04
Hi there, @Rhayden1231. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest making sure you've also tried all steps provided below:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer06-16-2023 04:04
06-16-2023 04:04
