07-13-2023
15:21
07:28
07-13-2023
15:21
07:28
At first, my Versa 2 was automatically restarting over and over again on its own, then it stopped powering on altogether. It won’t even charge anymore. I have cleaned it and the charger. Advice?
07-14-2023 07:35
07-14-2023 07:35
Hi there, @Debzo1221. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?.
If the restart doesn't work and the Versa 2 does not vibrate while trying to perform the restart, I'd suggest double checking you also tried the following:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove the Versa 2 from the phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
07-14-2023 19:55
07-14-2023 19:55
I have already tried all of these steps, and the watch is not responsive at all.
07-19-2023 06:34
07-19-2023 06:34
My Versa 2 Fitbit no longer charges or powers on. I have tried all (yes, ALL) suggestions given to me on here. Thank you for your help, but I do feel I need a replacement at this point. Who do I reach out to concerning this?
