03-02-2024
03:05
06:25
03-02-2024
03:05
06:25
My versa 2 seems to have gone blank on me.Battery is at 18% .Is not working no matter what I try,ie charging.
03-03-2024 06:30 - edited 03-03-2024 06:32
Hi there, @eileen-. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is still not turning on or charging. I will do my best to help you with this!
As a first approach, please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 2. I would recommend trying this maybe twice in a row if a first try doesn’t work.
Lastly, please make sure that your Versa 2 is up-to-date.
03-28-2024 05:58
03-28-2024 05:58
I did try everything versa 2 does not respond to anything
03-28-2024 13:04
03-28-2024 13:04
Hi there, @Diedericksmgc. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
03-28-2024 21:19
03-28-2024 21:19
