07-14-2020
11:25
12:43
07-14-2020
11:25
12:43
My Versa 2 was working this morning just fine. Looked down about noon and noticed it wasn't on. Tried to turn it back on and nothing. I'm not near my charger, but, will try that when I get home. I have had issues with Fitbit technology in the past. I hope this isn't another one.
07-14-2020
12:17
12:42
07-14-2020
12:17
12:42
same exact issue with mine!
Moderator Edit: Formatting
07-14-2020 12:47 - edited 10-02-2024 11:19
Hi there @PennStater2019 and @Jammbard, welcome to the Community Forums. I'm sorry to hear that your Versa 2 smartwatches' screen won't turn on. I'll be glad to help you both with this.
In order for me to better assist you with this, please try the steps below:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may be that the battery of your Fitbit is not charging properly and therefore it does not turn on. Said that, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
I'm looking forward to your response, keep me posted.
07-14-2020 12:59
07-14-2020 12:59
I was able to restart the Versa 2. The battery showed it was very low. I'm wondering if I thought I had it on the charger, but, didn't have it set all the way. I will try that today and see if that was the issue.
07-14-2020 13:08
07-14-2020 13:08
Hey there @PennStater2019, thanks for the update. Sure thing, keep me posted on the outcome.
07-14-2020 14:11
07-14-2020 14:11
07-15-2020 07:07
07-15-2020 07:07
Marre,
A very detailed approach towards resolving the problem!
Let’s hope it works.
Good work!
GS
07-15-2020 11:24
07-15-2020 11:24
Hello there - i followed all your steps and my Versa still won't turn back on. It's not even a year old so I hate to think it's already broken. Please advise.
07-15-2020 11:33
07-15-2020 11:33
The same thing happened to me with my Versa. Was working up until 4:00 pm (ish). Thought it died and needed to be charged as the battery was low. Thought my 'charger' was broke. Went and bought a new charger today (7/15/20) and nothing.... of course, my 1 year was up on 7/5....
07-15-2020
13:29
04:09
07-15-2020
13:29
04:09
Meleana,
Sorry to hear about your Versa going dark.
After charging mine for several hours I disconnected it from the charger and had to hold the button for around 20-30 seconds. It finally came on.
If it comes on you might try doing a factory reset but REMOVE YOUR VERSA FROM YOUR FITBIT APP ON YOUR PHONE FIRST. When it finally comes alive hold the button down again until it vibrates long. That should reset it.
If yours doesn’t I’d suggest calling Fitbit.
I’ve attached a link to the warranty that you should review.
https://www.fitbit.com/legal/returns-and-warranty
I’ve received several emails in the last 24 hours from people having the exact same issue.
Makes me wonder if Fitbit did a software push or something.
Good luck
GS
Young Tribe,
Sorry to hear you’re having issues.
fyi
I’ve got several emails in the last day or so from people having their Versa watch go dark.
Very Strange.
I wonder if Fitbit will just replace it if you return the old one?
Good Luck
GS
Best Answer07-15-2020 13:35
07-15-2020 13:35
I was able to get it back on yesterday enough to see the battery was almost completely drained. It may not have charged the day before and I just didn't see it. I put it on the charger for about an hour and it is fine so far. I think it popped out of the charger and I didn't notice.
07-15-2020 13:54
07-15-2020 13:54
Best Answer07-15-2020 13:54
07-15-2020 13:54
Interesting because TheYoungTribeNC mentioned their versa going dark 4pmish, which the time mine went dark. Makes me wonder if there was some sort of SW push from Fitbit. And maybe that's why when I called service they sent me a return label to send it in. And I'm 3mos past my 1 year warrenty. We'll see I hope they send me a new one.
07-15-2020 14:04
07-15-2020 14:04
Best Answer07-15-2020 15:16
07-15-2020 15:16
Glad I seen this post because mine did the same thing and my Fitbit is only 4 months old I was told I had to pay to return it. I just sent a email asking why.
Best Answer07-20-2020 13:26
07-20-2020 13:26
I have a similar problem. When app updated everything went sour. Tried all suggestions from Troubleshooting but nothing worked. Now watch won't come on and even though it is recognized in Bluetooth message says incorrect PIN number. $150 shot. Good luck with yours.
07-20-2020
13:42
04:12
07-20-2020
13:42
04:12
I would contact their customer support, they are sending me a new one because of the update messed up mines. They call the problem *reboot update* if that helps.
07-20-2020 13:52
07-20-2020 13:52
07-20-2020 13:55
07-20-2020 13:55
I got my versa 2 about three months ago and worked fine. I didn’t wear it this sunday and as I was going to put it on monday (today) it wouldn’t turn on even when charged for a few hours.
I tried to restart it and held the button for several seconds without the logo appearing or any sign it was still working.
please help
Best Answer07-20-2020 13:56
07-20-2020 13:56
No problem, good luck.
