11-17-2022
12:09
12:36
11-17-2022
12:09
12:36
Hi there, I have a Versa 2. It suddenly turned off, stuck with a black screen, and it won't charge. I cannot restart it by pressing the side button, and cannot update anything on the app. It appears completely dead, but I have had no issues with the watch or battery up to now.
11-19-2022 12:38 - edited 06-09-2023 03:59
Hi there, @ClaireAmy93 @sweetheart3986. Welcome to the Community Forums. Thanks for the details provided in your posts about the issue with your Fitbit devices.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work and your Versa 2 does not vibrate while trying to perform the restart, please make sure you've followed all the steps provided below:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
11-18-2022 00:40
11-18-2022 00:40
Same thing happened to mine 3 days ago. Recent update, Fitbit began to act unresponsive, nor was I receiving notifications or messages, yet calls and app were syncing. Then screen stopped responding to touch, but button worked. Now, it's not charging at all. Never had an issue whatsoever until the last update and seems to make me wonder why this sudden change ? I can't think of anything else that could have caused the issue.
11-20-2022 08:56
11-20-2022 08:56
What do you suggest if the above doesn't help and I cannot reset my Fitbit? I take care of my fitbit and it was operating get until I had to update the software. Slept after the update, the screen was unresponsive and then it went black and I have tried all that you recommended. I even purchased a new charger in hopes that was the issue but nothing has made any difference so far. My Fitbit was a gift so I'm not sure how to go about a warranty claim. Any advice would be greatly appreciated
